Where to get oil feed fittings
aaronscomp
Car: s13
I just got a ebay turbo i no it sucks but it was cheap its a t25/t28 exhaust i need a oil fitting that will fit it ad fit in my oil feed line also. The threads in the turbo for the oil feed is bigger than the sr t25. Where is a good place to find fittings. Heres the link if it helps http://cgi.ebay.com/ebaymotors...ories
driftin_sr20det
Car: 92 Coupe
Hmmm... Yes cheap. Well I would probably guess its 1/8" NPT thread size. I would just get 1/8" to an-4 or 3 whatever your using from summit or ebay.
ka-t 300
aaronscomp wrote:I just got a ebay turbo i no it sucks but it was cheap its a t25/t28 exhaust i need a oil fitting that will fit it ad fit in my oil feed line also. The threads in the turbo for the oil feed is bigger than the sr t25. Where is a good place to find fittings. Heres the link if it helps http://cgi.ebay.com/ebaymotors...ories
jgs or atp turbo
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
http://www.atpturbo.com/Mercha...=GTBB
There you go! Btw I wouldn't boost over 9-10psi with that turbo. Especially if U are unbuilt.
