Where to get lifters online?
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
My 90 240sx's (KA24E) lifters are getting pretty noisey. Does anyone know where I could get a set online for cheaper than the dealers' outrageous prices? Thanks in advance for the input.
adrock
You probably don't need an entire set. On the SOHC KA each lifter is part of a Rocker Arm/ Hydraulic Lifter assembly. They're self-adjusting. You can find them in parts stores for around $25 each. They probably won't have them in stock but will be able to order them. That's not a bad price for such an essential part of your valvetrain IF you can narrow it down to which one you need. This can be done using an automotive stethoscope ($10) or if you're cheap and experienced, a long screwdriver. Hold one end against your valvecover and the other against your ear (with your fist around it, I'm not trying to encourage ramming a screwdriver in your ear) and by moving it over each cylinder on both sides of the engine you can narrow it down to the noisy valve.
Remember you have 12 valves total, 2 intake and 1 exhaust for each cylinder. Intake valves are on the passenger side of the engine, exhaust on the driver side. See attached photo, it's exactly what you'll see once you've removed the valve cover.
There are 4 part numbers total for the different valve locations. One number is for the front of each pair of intake valves, one for the rear intake valves, one for exhaust cylinders 1 & 3, and one for exhaust cylinders 2 & 4.
Anyway, hope that helps. If you were already aware of all that and just needed a source for cheap lifters, sorry for the length.
-adam
niznos
Sorry for the Length?! Don't Be! That was about as perfect as the answer could get. I did know some of that infomation, but no matter, someone will hopefully find this thread later on a search and be completely informed by it, so the length and detail is great.
Only thing I didn't know is that the lifter assembly could be replaced one by one. I was under the assumption that you were supposed to do it by the set, but hey, even better that you could. Saves money.
Thanks for the great info.
