Postby
Q451990 »
https://forums.nicoclub.com/q451990-u142.htmlSat Mar 03, 2012 9:56 am
Are you talking about the fuel pump control unit? I don't think it would hum... that's typically the pump itself.
If you need one, I have a few used ones laying around... they typically go for about $50. I check them for melting and deterioration around the connector and transistors that usually get baked when they fail.
Postby
HooverSA »
https://forums.nicoclub.com/hooversa-u194514.htmlSat Mar 03, 2012 3:15 pm
Another option if you do need to replace your FPR would be to buy one that is after market. That's what I did. Relocated it and everything. Works great. Only downfall is you will need to tune it but if I remember correctly, you tune it to like 33.4 lbs or something like that when at idle. Most aftermarket versions have a gauge built in.
