Where to get different springs for coilovers??
C3Sierra_S2000
Car: 1997 240SX SE LS swapped
I just picked up a car with Cusco coilovers and they have what I was told was 10K and 8K springs on them which are wayyy too stiff. Anyone know where I can get different springs with softer spring rates that will work with the Cusco coilovers?
I was thinking that if the springs are the same length that I would move the rear springs to the front and look for some 6K for the rear. I am in Iraq so I don't have the car in front of me to check. If anyone can help I would appreciate it.
Tim
Endura-Tech
IF you find that the Cusco springs are a 200mm free length (8") and have an ID of 62mm (2.5") then I can be of assistance to you. Go to http://www.endura-tech.com and we have coilover replacement springs that are 6k, 8k and 9k in springs rates.
I think that you would find the 8k in front with a 6k in the rear to be ideal and all you would have to do is swap the rear to the front and buy the 6k (as you suggested in your post).
Best regards,
adrianfromthecastle
Car: 1992 Nissan 240sx
C3Sierra_S2000
Thanks for the info.
