Where to get clips like this?
schwim
Car: 2010 Nissan Altima 2.5S
Hello there everyone!
I usually have good luck on Amazon when I need clips but this one is throwing me for a loop. The car had been in an accident before our ownership and it was a bubba repair, leaving All the broken clips and holding all the plastic panels and hard lines with baling wire. This specialty clip seems to have had the job of retaining the power steering hard lines that go above the oil filter. It should have a barbed end to fasten it to the unibody but that is the part that broke off.
Could someone tell me if this is a clip I'd be able to get or should I try to make some sort of saddle to use with zip ties to hold the lines in place?
Thanks for your time!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
ConceptZPerformance sells a bunch of the different OEM ones.
https://conceptzperformance.com/nissan- ... p_2514.php
