evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Dec 08, 2008 10:25 am
I'm using 280 strut housings, they have a slightly larger internal diameter which makes the whole fitting of the strut easier, I've heard of people using 240 struts only to have to have the inside holed to fit the insert
the only other difference is the spring pearch height, if you intend to do coil overs that doesn't matter, the front bearings and brakes are interchangable,a nd the rear stub axles and bearings are interchangable, the 280z stub axle is suppose dot be stronger and is what I am running
