Where to get backside terminals for fuse block?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
XavierBK
Car: 2011 Yamaha Stryker
1985 Nissan 720
Hey guys, I'm wanting to hard wire my phone charger and FM transmitter right into the fuse block. My truck doesn't have a defogger or air conditioning so I could use either of those empty spots. Problem is, neither have the (-) side terminal on the back of the fuse block. Anyone know where to source them? Are there universal ones available that'd fit? Appreciate the help.
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
You may be able to get female terminals to fit into the fuse block. You have ATC style fuses, right? (Two small blades that extend from each side of the fuse). You may have to remove the vinyl or plastic insulators that come assembled with the crimp on connectors, I'd recommend using heat shrink to the wires once you crimp them anyway. The little tabs that hold them in may not lineup you'll have to compare with the existing ones in your fuse lock for other circuits. There are different sizes that depend on the size of wire and terminal that is inserted.
Most electrical suppliers should be able to find the right one. Here is an example http://www.grainger.com/Grainger/POWER- ... Pid=search
Return to “Datsun 720”
