I guess after seeing 3 peoples pans now, I'm just going to modify mine to make it shorter and wider. Will be cheaper than a new pan, and I haven't found a used one that isn't damaged.
Thanks for all the help.
CrazyTrance wrote:Thats actually what i'm doing right now to mine... I've cut the bottom and raised it up so i have more ground clearance. Then i'm adding extensions off the side to increase the capacity. There will be trap doors on the extensions so the oil doesnt go and fill up the sides under hard turning. But because i've raised it up I'm cutting and relocating the pickup tube up to compensate for the shorter pan.
Do you have any pictures of your progress?? I would be very interested in getting some ideas before I hack into my pan.
Steve
