Where to get an LSD for my S13?
uncle_louie83
Car: 1993 Nissan 240sx Coupe
didnt know where to put this so i posted here...since im sure some of you here have lsd's...
where can i get a good reliable lsd than can handle around 400hp? will a stock silvia lsd work? if so where can i aquire it at....price is not the problem...its finding one...please post some links if you can people...i dont have alot of time in my day to sit for hours and research so thats why im asking you....otherwise id sit and search...thank you for your input...
Lewis
hannibal
Car: Red Line to Glenmont
uncle_louie83 wrote:where can i get a good reliable lsd than can handle around 400hp?...price is not the problemLewis
Ive heard good things about Kaaz and Cusco LSD's. Theres always the Nismo diff. Stock VLSD are hard to find. The J30 diff will bolt in, so most people use that one.
Honestly, I think a OEM VLSD could handle the power, but if you want to spend money, get a clutch type LSD. Do some searching and learn what the 1.5 and 2 way mean. Then come back and tell me
DammitBobby
Car: S13 91 KA24DET
J30 95 or 96 direct bolt on. Junk yard for about 200 bucks. Make sure you get the 2 bolts and washers that bolt the front carrier.
Import_Ant
rseabrooke wrote:J30 95 or 96 direct bolt on. Junk yard for about 200 bucks. Make sure you get the 2 bolts and washers that bolt the front carrier.
you can use the earlier models too but you have to get the axles also. This goes for NA 300zx diff's too. (the turbo diff will work but it's geared ALOT lower and will screw with your speedo and really bog the car down)
You'll have to swap over your diff cover but this is the most cost effective option. I think this series of diff is classified as R200
crzycav86
Car: 93 Nissan 240SX KAT
If you ever have plans on going ka-t(you did post it here anyway) the j30 vlsd will probably be optimal because it has a slightly higher gear ratio. Get one with 3x2 output-shaft bolt pattern for the easiest swap(I think those are post-95 j30's).
Next time, post this in the suspension/brake forum, or 240sx technical. I don't know why you'd post it here.
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
Yeah the j30 lsd is a breeze to install as long as you get the 95+ differential. Also you might want to stay away from the kaaz or cusco, unless youre hardcore about driving and drifting. The rattle, ride rough, and you have to service them every 3000 miles.
nismo1003
Car: Ka24de
mmatl16
Car: 240sx rb20 swap
vlsd's arent really that hard to find. i got mine for 220 with new axles.
http://www.venus-auto.com
