Where to get a key cut?
SEBZX79
I bought a blank from ebay and need it cut.The dealer said they have to send it away to get it laser cut.I cant do that since it is the only key that I have any idea who does this?
Rex
Car: None
SEBZX79 wrote:I bought a blank from ebay and need it cut.The dealer said they have to send it away to get it laser cut.I cant do that since it is the only key that I have any idea who does this?
Well, they should be able to have it cut by the VIN # and not need your key, but I didn't know they cut "inexpensive" ebay keys.
I have an "inexpensive" key, I had cut at a real locksmith. Check your local Yellow Pages for a locksmith with laser key-cutting capabilities.
I had to go back a couple times as they laser guy was out getting recertified and then went on vacation. It is somewhat of a specialty.
szh
Car: 2018 Tesla Model 3.
Hmmm ... I had a couple of extra copies made by a simple key maker at some mall locally without difficulty. Many of them can now do the reverse key copies.
The dealer should be able to use the VIN or key number (came on a tag with the original car sale - in a very neat little oval box!)
Z
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Ebay keys are not for everyday use ( there is a reason why they are less expensive than OEM).
McLock Locksmith(864) 934-3411 or (864) 231-9671E-mail: [email protected]
tkd_q45
My wife picked up one of those cheapie Q Keys and we had it cut at the local locksmith. Works just fine and we've been using it for years. Just looks LAME!
Mark86T
Car: 96 Q45, 86 Z31T, 01 Ford Ranger, 77 280z
maxnix wrote:Ebay keys are not for everyday use ( there is a reason why they are less expensive than OEM).
Wow. I have Ebay cheapies that I use everyday in my Q. I don't wanna use the titanium one all the time. Plus it's longer than the copy. Had to have a locksmith cutmine. $25 each key. Ouch. Dealer wanted $150 for a key. No thanks.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I have a cheapie too that was used for a while...
For $20 and even if you have to replace it every 2 years, thats fine with me..
I still have my burlwood momo blank i need ot get cut.....
Rex
Car: None
The key's not the issue as much as what it leaves inside the tumbler. If you use it all the time, you'll slowly notice the key not going in/out of the tumbler as easily and the key placement withint the tumbler becomes more important in the turning of the key.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Rex gets the Bingo award. Two, three years, you are OK. Later, when you have to replace your locksets, you will wish you had used an OEM blank without extra keys hanging off the ring.
elwesso
2007 BMW M Coupe
Also, to add to the madness, a new lock set is about $1000 installed.....
Rex
Car: None
So, the long term smart money is on buying a key from Joe, but a "cheapo/ebay" key is okay for limited use as a spare.
94Q45
Car: 1994 Q45
I went to my local infiniti dealer in chicago and I bought the key there and they cut it for $17.00 the factory infiniti key is $70.00 as im sure you could tell I went with the $17.00 one.
