Where to find Z32 rear rotors drilled fo' 4 lug?
Dammitboy
Car: 92' Nissan 240
Hello, as stated, looking for 4 lug z32 rotors rotors (preferably brembo) to complete a rear z brake swap. Any ideas besides enjuku???
Thanks!
fetherw8
Car: 1989 240sx
my friend just re-drilled his z32 rotors to fit his 4 lugs. it worked, no problems.
Dammitboy
Car: 92' Nissan 240
I'd like to find some new drilled or slotted ones. All I could find were circuit sports rotors, which I know 0 about.
1unar3clipse
Car: 93 240sx HB, 01 Dodge Dakota SLT
Heavythrottle?
Ebay?
DIY?
brizanden
Car: thrased kouki ftw
chicken? CATS?
DOGS?
IDK ALL I DO IS SPEAKS IN CAPS AND QUESTIONS
Dammitboy
Car: 92' Nissan 240
brizanden wrote:chicken? CATS?
DOGS?
And this helps me how? Respond if you have somthing useful, you jackamonkey.
DarkPhoenixWS6
Car: 1990 Nissan 240SX SE FB
Tirerack.com has them. Pretty cheap too. You will have to redrill for 4x114.3 though.
lofapoo
Car: Toyota sedan
Jackamonkey, I like that.
Buy Brembo blanks. Take them to a machine shop and have them redrilled to 4x114.3
BAM!
eazye2000
Car: S13 KA-DET
Put a stock rotor on top of the 300zx rotor, and use one of the holes that's already in the 300zx one. Then center the hub holes as close as you can.
Then grab a 1/2" drill bit and have at it.
You can actually make the holes a slight bit bigger than stock in case you didn't mark your holes 'perfectly'. The rotor centers on the hub hole anyways. So no biggie.Nay-Say all you want. I've done it quite a few times with no problems. Only cost me one high quality drill bit.
Some say it will weaken the rotor. Only seen the VR-4 rotors break from this.
Just my $.02 Take it for what you will.
hannibal
Car: Red Line to Glenmont
PDM sells Z32 Powerslot rotors and charges $20CAN to redrill to 4 lug. Hell, you can buy a new drill for that much.
As far as Brembo discs, NopiOnline.com sells blanks at a great price...
