Where to find the #'s for bearing selection?
daz1320
Car: '93 vert
I am replacing my rod and crank bearings.I found the numbers on the crank.I just want to be sure about the block location.If anyone has pics please post them up..
180fan
Car: 89 fastback
at the back bottom of the block. You'll see a series of numbers there. Those are the ones you need.
daz1320
Car: '93 vert
The ones just below SR20? If that is where they are then do these look correct 730757 A?
sr20-thoj
Car: 89 nissan 240sx coupe
you should do a write up.. im actually going to change my bearings soon too...
ca18det_boy
when you pull the head, towards the flywheel side on the actual deck...there are numbers there. You need those numbers and the ones on the crank. So the head needs to come off in order to get the proper #'s.
daz1320
Car: '93 vert
I talked to the guys at Enjuku and they told me where the #s are.I got the ones on the crank and they told me to look where the upper oilpan meets the block.I loooked and there they where.I called back to confirm and those are the correct #s.I'm not saying that you are lying but are there more #s on the head-side of the block that I should be concerned with?Also how(or who from) do you order bear4ings with these #s?
ca18det_boy
bah, my mess......it IS under the upper pan......sorry for the confusion......
