why would you even bother wasting your money on the ebay special if you're gonna replace the muffler with a tanabe/borla/magnaflow anyways? it's just not worth it. Get the axelback exhaust of your choice (tanabe and borla already have nice exhaust tips, so no money spent there), and just have an exhaust shop bend you some piping from the cat to your muffler. it'll cost you the same, if not less than the $275 you'd be spending on the catback and tips, and you don't have to deal with the crappy ebay muffler afterward.mattybo wrote:Why not? From everyone I have seen who has purchased it, it's worked fine. It's just a muffler with some 2.5" piping. I am going to be changing out the tips for magnaflow stainless steel tips. It's cheaper than having an exhaust shop run a custom exhaust which would be the same quality. Id rather spend 175 on the full cat back exhaust, 100 on 2 magnaflow tips then drop 500-800 on the tanabe/magnaflow/borla. Already spent enough on this car. This is the last thing I am doing.
Sometimes using money wisely does the trick. In this case I paid a grand total of $300 some dollars, including the $175 for the ebay exhaust, from start to finish, for a 2.5" mandrel bent exhaust that is still working great after 42,000 miles.RED_DET wrote:Why would you put an ebay exhaust on your 30K+ car?
Read carefully. He said he'll replace the tips with something nicer from Magnaflow etc., not the muffler, just like I did. The muffler itself is great, it's the bend and design (or lack thereof) on the outlet/tips that is in need of fixing due to their odd appearance and angle.downedzephyr wrote:why would you even bother wasting your money on the ebay special if you're gonna replace the muffler with a tanabe/borla/magnaflow anyways? it's just not worth it. Get the axelback exhaust of your choice (tanabe and borla already have nice exhaust tips, so no money spent there), and just have an exhaust shop bend you some piping from the cat to your muffler. it'll cost you the same, if not less than the $275 you'd be spending on the catback and tips, and you don't have to deal with the crappy ebay muffler afterward.mattybo wrote:Why not? From everyone I have seen who has purchased it, it's worked fine. It's just a muffler with some 2.5" piping. I am going to be changing out the tips for magnaflow stainless steel tips. It's cheaper than having an exhaust shop run a custom exhaust which would be the same quality. Id rather spend 175 on the full cat back exhaust, 100 on 2 magnaflow tips then drop 500-800 on the tanabe/magnaflow/borla. Already spent enough on this car. This is the last thing I am doing.
"then" was probably meant to say "than"downedzephyr wrote:why would you even bother wasting your money on the ebay special if you're gonna replace the muffler with a tanabe/borla/magnaflow anyways? it's just not worth it. Get the axelback exhaust of your choice (tanabe and borla already have nice exhaust tips, so no money spent there), and just have an exhaust shop bend you some piping from the cat to your muffler. it'll cost you the same, if not less than the $275 you'd be spending on the catback and tips, and you don't have to deal with the crappy ebay muffler afterward.mattybo wrote:Why not? From everyone I have seen who has purchased it, it's worked fine. It's just a muffler with some 2.5" piping. I am going to be changing out the tips for magnaflow stainless steel tips. It's cheaper than having an exhaust shop run a custom exhaust which would be the same quality. Id rather spend 175 on the full cat back exhaust, 100 on 2 magnaflow tips then drop 500-800 on the tanabe/magnaflow/borla. Already spent enough on this car. This is the last thing I am doing.
problem solved.mattybo wrote:Why not? From everyone I have seen who has purchased it, it's worked fine. It's just a muffler with some 2.5" piping. I am going to be changing out the tips for magnaflow stainless steel tips. It's cheaper than having an exhaust shop run a custom exhaust which would be the same quality. Id rather spend 175 on the full cat back exhaust, 100 on 2 magnaflow tips than drop 500-800 on the tanabe/magnaflow/borla. Already spent enough on this car. This is the last thing I am doing.
i did. if you read it the way it was written, "then" implies it's the next step, while "than" implies instead of. it's a simple problem of internet grammar. good catch IBCCoupeVQ35CVT wrote:Read carefully.
Hah yah I assumed he meant "than." No problemo.downedzephyr wrote:problem solved.mattybo wrote:Why not? From everyone I have seen who has purchased it, it's worked fine. It's just a muffler with some 2.5" piping. I am going to be changing out the tips for magnaflow stainless steel tips. It's cheaper than having an exhaust shop run a custom exhaust which would be the same quality. Id rather spend 175 on the full cat back exhaust, 100 on 2 magnaflow tips than drop 500-800 on the tanabe/magnaflow/borla. Already spent enough on this car. This is the last thing I am doing.
