What would you need for a backspacing to run said tire size on said wheel on an S-13, w/o much pulling?rb25drag wrote:What size tire are you planning on running?With a 15x10 wheel More than likely your gonna have to roll or cut ur quarter panels to get them to tuck.With a 15x8 wheel and a 26x10.5 et street unless your makking over 1000hp you should have No problems hooking at the track.
I dont know the exact measurements, But I can give you mine and let u figure it out.I have a 8inch wide wheel with a 4.5 backspacing, = 0 offset, With a 275-60-15 Dr With my camber set at 2degrees It sticks out 1inch of my fenders, If I put more camber in it I can clear But then I loose Tire on the ground. So Personally Im gonna go with a 26x 10.5x15 Which is about 9 inches wide on a 8inch rim = Profection at the track + No work on the fenders = money saved.240_SeX wrote:What would you need for a backspacing to run said tire size on said wheel on an S-13, w/o much pulling?
That's not going to fit w/out serious work...listen to rb25drag. A 10" needs a 6.5-7" Backspace to fit well. You'll be fine w/ an 8" or 9" wheel.meet07 wrote:Seems that the summit racing drag rims are a good buy. I just gotta figure out the offset I want. Im leaning more toward the 5.5 with the 15 x 10 setup. That will put me at a 0 offset. I dont think summit offers anything higher.
