Where to find fluid capacity of diff and drain/fill transmission
O5Q45
Car: 2005 Q45 Base sedan
Anyone have any idea how much gear oil is required when I change out the differential? Transmission quarts that drain and refill? Going to use all Royal Purple unless anyone here has a reason not too.. from what I'm researching there film strength and cooling ability is superb-
Q451990
Should be in your owner's manual in the DIY section. Transmission capacity is more of a drain, refill with about the same amount, check dipstick and repeat operation. I usually get about 3-4 quarts out of our G. Please be sure RP ATF meets Nissan's specialized requirements for ATF.
