Where to find driver's rubber floor mat for cheap?
fooitm35x
Car: 2007 M35x
Where can I find the driver's OEM or 3D maxspider rubber floor mat?
eBay prices are like our cars were new and in production 10 years ago.
For some reasons floor mats can't survive long with me - I am on my 3rd rubber floor mat.
I am using all weather rubber floor mats year round.
EdBwoy
Unfortunately, I have no idea either, but I can find you all passenger floor mats somewhere. I use the rubber mats throughout as well, and although my mats are all still in good shape, I dread the day my driver one develops a crack/hole right at the heels area.
Good luck, and if you find a solution before I post my update, share with us.
Larz
Car: 2019 Q70-L RWD
I don't know about "cheap" mats but it's very easy to find OEM mats in rubber or carpet. I'm not sure cheap is the way to go especially on the driver area. That gets the most wear by far and the cheaper you go, the more often you will need to but them.
I doubt you can find JUST a driver side mat. You will probably need to buy at least both sides for the front unless you buy a used mat and that will wear out even quicker.
Considering that the mat is the only thing between you and permanent stains on the carpet, I spring for good mats. It's so much less to spend over time.
EdBwoy
fooit, check your PMs
