Grant@tirerack »
https://forums.nicoclub.com/grant-tirerack-u8792.html
Thu Nov 06, 2003 3:12 pm
Whenever you re-do the brakes, it's a good idea to get a caliper hardware kit to replace the spring clips, pins, or any small anti-rattle harware. All of those small parts are subjected to a lot heat and will not perform well. It's cheap insurance. Most local parts shops will be able to get you a hardware kit. If the factory pads have shims they can be reused but it's best to replace them. Those should come in the hardware kit if needed. Don't forget to check your fluid. If it looks like tea or, even worse, coffee, change the fluid.
