jtesensky wrote:Sorry just noticed your "97Q" in the post subject line. The OEMs aren't $500 each, but they're not cheap either:
Front struts: $221.11 each
Boots: $20.66 each
Bearing: $15.60 each
Mount (if needed): $59.15 each
Total: $633.04 (w/mounts, $514.74 without)
If they have 89k, how much more life do you expect they would have? I'm tempted to go the used route, but I feel like I would run into the same problem a few years down the line. Also, what would the price be?htbyrico wrote:you looking for the set? or just one? have some over here at the shop used.. they have 89k on them.. no leaks OEM Nissan/Infiniti
your cars birthday before 05/97 or after 05/97 ?
Depends on your tolerance for repeat labor and different wear rates producing different damping rates for front vs. rear.garyp15 wrote:If they have 89k, how much more life do you expect they would have? I'm tempted to go the used route, but I feel like I would run into the same problem a few years down the line. Also, what would the price be?htbyrico wrote:you looking for the set? or just one? have some over here at the shop used.. they have 89k on them.. no leaks OEM Nissan/Infiniti
BadQ45t wrote:actually that isn't all that much. i spent more back in the day on springs and struts/shocks. But that was 5+ years ago and I knew the car had at least 10 more years of service for me. But if you can get a good set of coilovers that are new for 825 that is a great deal.
