Where to drill oil Pan?
300max
Car: 1995 240sx ka-t 1997 Maxima SE
I read a post on here that indicated I should drill it at 3 inches over and 1 inch down. However that didn't work, the AN Nipple I JB welded on was too close to the power steering bracket and the female AN would not fit over top of it.
I'm on oil pan #2. Does anybody know if 2 inches down from the lip is too far. Will it put the return below the oil level?
Thanks
boost infested
Car: cars, chicks, food, and .....
Nismo_Freak
Car: 89 Nissan 240SX
He asked a valid question... chill out killer
WDRacing
Yeah, I have this rule that says you can ask pretty much whatever questions you want as long as they are related to the KA24DET. If thye need to be closed or deleted I'll go ahead and handle it. I hate when people say "search". I'd rather you just didn't reply at all.
DammitBobby
Car: S13 91 KA24DET
While on the subject of installing plug in the oil pan. Somebody told me about a self taping plug they use on transmission pans that could be used for the oil line for the turbo. Anybody have any experience with this?
Thanks
WDRacing
A simple 5/8 barbed fitting from Home Depot will work great.
DammitBobby
Car: S13 91 KA24DET
Thanks WD
boost infested
my bad, i was trying to be sarcastic. but i did post...
WDRacing wrote:Yeah, I have this rule that says you can ask pretty much whatever questions you want as long as they are related to the KA24DET. If thye need to be closed or deleted I'll go ahead and handle it. I hate when people say "search". I'd rather you just didn't reply at all.
WDRacing
boost infested wrote:my bad, i was trying to be sarcastic. but i did post...
I still love you....
okis14
This is what mine looks like. It may be a little low though. I'm hoping it won't be a problem.
All the oil you see has been cleaned up and nothing leaks.
300max
That's exactly where I'm putting mine.
It ended up being exactly 3 inches over and 1 3/4 inches down.
Thanks for the information.
