I guess I ought to go more in depth as to the purpose for this car. It will mostly be street driven, but by no means a daily driver. This will purely be a toy to take out for fun whenever I'm in the mood, and to the drag strip (and maybe auto-x, I've never actually been to an auto-x so idk how I'd be at it, and I especially don't know how a 300+ whp FWD car would do on such a tight track) whenever I have time.
When I said pull a Z06, I didn't necessarily mean from a dig, although if I could then all the better. I was thinking from about 70mph to my limiter. At the very least stay even with it, as that would be an amazing feat in and of itself. I don't think I could fit anything wider than a 205 under the front, but that may change with coilovers. But as this won't be a DD I plan to only take it out on dry sunny days and have no problem running some Nitto NT-01s or Hankook Ventus R-S3s. Even so, I don't expect to get a Z06 at the launch unless it's at the track and he has some hard economy tires for some reason. As my CA sits now, in a 1987 Pulsar, gutted out completely (not even a dash, heater, blower motor, anything), weighing 2300lbs and one-wheel-drive, it's light enough that even spinning tires it pulls hard enough to stay dead even with a G35 Coupe up to about 100mph. 200lbs is a lot of weight (I can easily feel a great difference with a 160lbs passenger), but I'd like to know how much of a difference having the VLSD would make. My Pulsar is also REALLY low geared. 4.47 final drive and in fifth at 75mph I'm sitting at close to 4k rpm. I think the VLSD transmission drops this down to about 3500 rpm, but my top end will still suffer.
Correct me if I'm wrong, but as an estimate drivetrain loss is about 10% for FWD and 17% for RWD. I figured at 2500lbs about 330whp should stay even with a Z06. Now in a 240, 400bhp may be needed to achieve this, but in FWD about 365bhp is needed. I do understand fully that torque is king in drag racing, which on the street is mostly all you'll do anyways unless your stupid. So idk how much of a difference that will make when comparing power to weight ratios.
float_6969 wrote:AFAIK, there are NO, 500hp FWD, STREETABLE vehicles in the world.
You may not know who he is, since he's a local around here in Huntsville, but Matt Tucker has an EK Civic Type R that at one point put down 622whp and was daily driven for a year before a rod went and he did a K swap. Idk how "streetable" it really was and I actually have no intention to match that. In any form, but especially FWD, if I would have trouble hooking up in fifth gear with say 500hp, then what's the point in going further. Not really trying to argue with you, float, about your point on that. His car just came to mind when you made that statement. It's been in a couple articles I believe. If you google "Matt Tucker CTR" I'm sure you'll find it. It's an amazing machine. I bet he gets tired of everyone drooling over it, lol.
float_6969 wrote:Would you try to build a Pulsar that's as fast a a Ferrari F430?
...Yes... lol, jk. I'm not really much to try to out do anyone or anything, I build what I want for my own gratification. I'd just like to have the Z06 thing as a good comparison. Plus if I ever do run one, it'd be great to put it to shame. Which, in a Pulsar, just keeping up would do that. But if possible, spanking it would be the best of all.
boost_boy wrote:If you want to talk more about these desires, pm me
I have permission to PM the almighty Dee??? I AM NOT WORTHYYYY
boost_boy wrote:To outright turn your pulsar SE into something wicked with no compromise and on an internally stock CA18DET, you are talking in the ball park of around $3500
That cheap?! lol, jk. I'll try not to state how much I'm planning on spending so I don't sound like some show-off or some ricer who thinks power is cheap (not going to say which it is). I'll PM you Dee and let you know what I have planned so far.
Thanks for your responses. And thanks for the confidence boost, Dee.
The not so personal stuff I'll put here in the forum for everyone's benefit. So back to the Q's.
Is there a definitive answer as to where the stock cams make max power with a turbo that will flow air that high? I was talking to a guy on here who said it was right at or just under 7k.
Just how much power can be had from the stock exhaust manifold? Using the power range from above I've figured a GT2871R can make as much as 350bhp at 26psi on a good day. Does that sound about right or would the manifold restrict this?
With cams, how much power can be made on a T28? Don't ask me what spec cams, for I have no experience with them. So just assume the best balance.
It may depend on the condition of the stock valvetrain, but at what point would it need to be upgraded so the valves don't float within a generous margin after the powerband (for reliability purposes)? Like what size cams? Not trying to make power by revving like crazy, but at some point the stock cams just won't cut it.
