Where To Connect parking BRake Wire for Turbo Timer?
rico05
Car: 1992 RMS13 w/ CA18DET
I suppose there is a sensor that is in the parking brake the tells the light in your dash to come on when the parking brake is engaged. Is it easy enough to find? I just want to check before I go ripping out my center console.
I will be getting this damn thing in as soon as it cools off a bit. Texas is teh suxx0r...
Silvia007
Car: 93 Nissan 240SX SE Fastback
Yep, there's a spring loaded switch (very cheap looking) at the base of the parking brake once you take out the center counsol. Can't miss it even if you tried.
SRdave240
I just hooked mine up to a ground and remember to pull my parking brake.
quiksilvia
Car: 95 s14 se
i used the spring loaded thing too, its kinda a biotch to work with cuz theres not a lot of slack in the wire, but thats whats used, i think its purple...
