Where to buy the steering wheel emblem??
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
reyes1212
Car: '07 Nissan Versa Super Black
Some friend of mine thought it funny to try and "steal/hide/jack/borrow" my emblem from the steering wheel, but failed while using a screwdriver and bent/scratched it up somewhat. I want to get it replaced, but can't find that specific part online...Does anyone know where I might be able to purchase one to replace my messed up one?
P.S. I'm not the one who is paying for it-->the dumb friend is.
audtatious
You may have to get it replaced via a Nissan dealership. I'm not sure how it mounts but I'm sure it won't come off easy as that could cause issues when the airbag goes off.
Your friend may have made a pretty expensive mistake.
1_Sleek_Versa
Car: 08 Nissan versa SL
I agree as for the expensive mistake.
This is why I'g go Sparco.
biggie
Yeah, try dealership. If not search junkyards. But may have to get the whole cover.
Your friend is dumb.
1_Sleek_Versa
As a little revenge I'd "steal/hide/jack/borrow" his fuel pump fuse in his fusebox.
grogman
Car: 2007 versa s hb at onyx blue
biggie wrote:Yeah, try dealership. If not search junkyards. But may have to get the whole cover.
........better yet.have your bff friend go for you and have him leave his gff and if he fails on his mission you get the girl................
Sure_Shot
Car: 2008 Versa SL Tech 6speed
Man, I have one. I can also tell you that the only way I got it off intact was from a blown airbag. It has little arms with holes in them that go into the airbag housing and another plastic piece inside the housing holds it there. I don't think there's anyway to put a new one on properly without replacing the whole deal. I'm sure you could glue one on or something, though. I would post pics, but I don't know how.
I would check salvage yards. I'm pretty sure it comes as part of the airbag only from the dealer. you could probably get it for next to nothing off a blown airbag in a yard. I'm willing to part with mine, too if you want. It's in perfect condition, as the car it came off had 2500 kms. Good luck!
reyes1212
Sure_Shot wrote:Man, I have one. I can also tell you that the only way I got it off intact was from a blown airbag. It has little arms with holes in them that go into the airbag housing and another plastic piece inside the housing holds it there. I don't think there's anyway to put a new one on properly without replacing the whole deal. I'm sure you could glue one on or something, though. I would post pics, but I don't know how.
E-mail me! It would be great to get one.
I still have the abused one and I can for sure put it back on and it stays it's just it looks effed up. The airbag is still good and nothing has happened. It's just a little piece of plastic and you can see the airbag rolled up through the three holes where the emblem goes.
Sure_Shot
I emailed you.
reyes1212
Ditto, thanks.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
The emblem should be held from the back side to prevent it becoming a 100mph projectile if the airbag goes off. It'd be best to get a new to you airbag installed (whether it's new from a dealer or a junkyard). Just make sure you disconnect the battery when you change the airbag.
grogman
Promise Land wrote:The emblem should be held from the back side to prevent it becoming a 100mph projectile if the airbag goes off. It'd be best to get a new to you airbag installed (whether it's new from a dealer or a junkyard). Just make sure you disconnect the battery when you change the airbag.
yeah and make sure you bring plenty of bling bling because if you have to tear into something that was once perfectly good and for no good reason it is not any good now.............it usually costs you a couple weeks of happiness.......so like i said........have your idiot friend go on a mission and if he fails to fix your dilemna............. you get the girl..................
blkverssa7
Car: nissan versa hatchback 1.8L
okay dokie i got it ...... its on evay go to the url here it is and your welcome
http://cgi.ebay.com/ebaymotors....m245
[IMG][/IMG] http://cgi.ebay.com/ebaymotors...72832
Return to “Versa Technical Discussions”
