where to buy SR20DET flywheel bolts ???
thanhsayz
Im getting my stock flywheel resurface and i need to get new bolts . Ive searched and found the size of the bolts , but i was wondering if you can interchange bolts from sr and ka . Its too late to call nissan , but i called courtesy parts and they said 4.90 a bolt , and i think i need 8 of them . Also I searched and found the size of the bolt to be 10 x 1.0 and 25mm in legnth . I went to boltdepot.com and could only find "Steel grade 8.8 fine threadMade from medium carbon steel and zinc plated. Best for general hardware use where high strength is not required. Fine and super fine metric thread pitches. " Id like to find some stronger bolts and with hex heads , because the 12point head bolts seems like a pain if they were to round off .Please , someone has to know , any info would be appreciated , and thanks in advance .
