biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Sat Dec 03, 2005 11:50 pm
Silly wabbit, lash kits are for SR's!
The CA's superior valvetrain has no need for, nor can it even use, a "lash kit" like the SR needs for high RPM operation.
For high RPM operation, see rico's post on places to find fancy stuff and such, but stock valvetrain can live at 8k RPM as long as the rest of hte engine is in good shape (i.e. oil pump), but without some wild cams you'll make ****e for power up there. If you want to go crazy you can go solid lifter, but you need the lifters, shims probably, and cams meant for them.. Tomei used to make the parts, they're same as RB26 IIRC or maybe it was RB25 except the cams of course..
