I currently don't have any shocks planned, although I may justgo with KYB AGX (or Tokico Blue).
So anywho, who sells KG/MM springs? Preferablly someone whoalso ships to Canada.
I'm basically after the stiffest springs my money can buy.
Exar-Kun wrote:tokico blue will no work with the stiff kg/mm springs, even the agx is only rated to 50% higher spring rates than stock...
you will have to adjust the AGX up pretty high to dampen those springs enough.
if you want really stiff springs, get a coilover setup, after you match the dampers to the springs you want(sayy..koni yellow, or KYB buzz specs) you'll be near coilover cost anyway.-chet
ca240 wrote:gonad you should check out the group buy in the buy/trade/sell forum, you can get that exact same spring rate with the d2 coilovers and they're only 640 shipped...check it out man
