Where to buy a rb20 oil pump gear???
oneruffryder42
ankWhere to buy a rb20 Crank Timing Gear?????? all i need is this little guy and i can get my motor running. any help??? thanks Ricardo
Modified by oneruffryder42 at 8:16 PM 8/31/2007
Modified by oneruffryder42 at 8:17 PM 8/31/2007
oneruffryder42
anyhelp at all is it the same as the 25 or 26??? need help plzzzzzzz thanks
oneruffryder42
Crank Timing Gear??? lmk this is whats its called thanks
wob
Car: 93 240sx fastback in the works
im on the same boat... i had to cut mine off a few months back so i could send my crank out to be machined...
ive been searching all over the net but came up with nothing... ive emailed nismoparts.com who usually get me out of my jams but to no avail...if u ever find someone who supplies them let me know as well its on my shopping list
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
hmm, time for me to run a CAD off of mine and have a few made, huh.
I figure the that all RB gears will be the same since they use the same timing belt length and cam gears.
Good luck with the search
oneruffryder42
ya i had 2 take mine off to put on my new oil punp. need help thanks
nismopwr240
Car: RB20 240sx
anyone find anything out? I have searched this as well. found one place, japanparts.com but there site wouldnt load. Anyone know of any other place? Thanks
digzsublime
Car: 95 S14 w/ LS1.
I just had to replace the crank timing gear on my 20. Bought one for an RB26. It's identical as far as I can tell. Fits perfect. Timing mark in exactly the right spot. I believe that while the Nissan part numbers are different, all the RB's use the same timing gears. I know the timing belts and cam gears swap between the 20, 25, and 26 so makes sense that the crank timing gear would be the same.
Anyway, I would call an engine importer. Check our sponsors. Ask them if they have any bad long blocks that they are parting out.
Could also try this link. http://www.japanparts.com/db/p...olkey
They only show one for a 26. But like I said, they are identical as far as I can tell. Hope this helps.
nismopwr240
Car: RB20 240sx
ok, thats the link i saw earlier at work, i guess it is just blocked at work because it opened fine here at home. The estimated delivery says about a month, did it really take this long to get it? Anyone know any other place that would be faster? Thanks
Bluefire
I might have one, email me at [email protected]
-Bluefire
skylinegrl13
Car: 1995 Nissan 240sx RB26DETT swap
they told me a month also, but i got it within the week, i couldn't find anyone else that had it ready for sale.
Coolwhip
Vendor
Might have some coming your way you guys, just waiting for the quote back from the machine shop.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
Cool I still need one for my rb20. Hopefully you know soon because I want to order one soon. Wont be long and well be drifting again. I think im buying a zeitronix too, to tune my p fc with.
nismopwr240
Car: RB20 240sx
ok thanks for all the replies guys, if Bluefire doesnt have one i will order one from Japanparts.com, thanks again
digzsublime
Car: 95 S14 w/ LS1.
I didn't buy mine from japanparts. I put the word out in these forums and someone came to my rescue and sold me one for a great price.
I did however make the mistake of saying "name your price, I'm desperate". I got lucky. I had one guy sell me one for a great price and other people emailing me wanting ALOT more than a new one costs.
Like I said, I'd call an engine importer and see if you can pick up a used one cheaper and faster. Hope you get it all going soon.
onepuff
digzsublime wrote:I just had to replace the crank timing gear on my 20. Bought one for an RB26. It's identical as far as I can tell. Fits perfect. Timing mark in exactly the right spot. I believe that while the Nissan part numbers are different, all the RB's use the same timing gears. I know the timing belts and cam gears swap between the 20, 25, and 26 so makes sense that the crank timing gear would be the same.
this link shows the same part number for half the price. just put in for an r32
http://www.japanparts.com/db/p...olkey=
skylinegrl13
ugh, i feel i've been had...
nismopwr240
Car: RB20 240sx
yep i got ripped for an r33 one as well. Nothing i can do now tho, just wait for mine to come in.
onepuff
you should call them up and ask why there is a price difference for the two. maybe you'll get lucky and get it for the cheaper price.
