Where to buy 7 heat range plugs?
Structure240sx
im upgrading my fuel system very soon and will be needing 7 heat range plugs now. i went to napa and they said they dont have any or cant get any ngk 7heat range for my 240. he said i need product number 6097 i think. i know rick (95_240sx) and dave (davEeee) are using ngk 7 heat range so where did u's get them? im looking to get a copper set or two for now then a set or iridiums later. im leaving in 12 hours to go on vacation and wont be back until the 14th but i will check the forums again at about 10:30 for the last time til i get back. any help would be great thanks -Anthony
klattr1
Car: GT42R powered S14/KA
Im running the same ones Rick and Dave are running.NGK coppers: part# BKR7E-11They cost something like $2 each whereas platinums cost like $10 each.I got mine from Advance Auto Parts. Auto Zone couldnt get them and NAPA would have taken a week for special delivery. Advance Auto Zone had them the next morning for me.Cheap, easy to get.The only disadvantage of copper plugs is that they dont last as longs as platinums or iridiums. I think people tend to replace the coppers every 10-15 thousand miles but at least they dont cost much at all.
C-Kwik
If you don't mind a small wait, PDM Racing has NGK iridium plugs for fairly cheap. Even in a 7 heat range. It doesn't look like he stocks the copper ones, but he might be able to get them...
http://www.pdm-racing.com/products/misc_tune.html
1998cc
Aren't z32 300zx twin-turbo plugs the 7 heat range. I could've sworn that was true.
Structure240sx
klattr1 and ckwik thanks alot ill check out advanced auto parts for now and get the irdiums later prolly
DaveEEE
Our shop gets em from pepboys.... NAPA can get em too (BKR7E-11 or BCP7ES, both have worked good for me), but take about a day to order most of the time.
Structure240sx
went to advanced auto parts today. they said they could only get 5 heat range. ill try pepboys later. could someone buy a set and ill buy them off u just incase i cant get a hold of them. i want/need them by next week
Structure240sx
i found clubplug.net. they have every plug u could need. they didnt have bkr7e-11 they did have bkr7es-11 so i ordered them. i didnt really think too much about it since i have bkr6es-11 now. i should be fine with those right? they did have bcp7es i prolly should have jsut gotten those to play it safe.
DriFt3r
Car: Racing and Drifting
hmmm what about iriduims. Where can I find those?
SingleCamSam
dude, read the whole thread...:P
Structure240sx
i got the plugs today from clubplug. the bkr7es-11 and they are the right sized and thread so they should work jsut fine. ill prolly be puttin them in on sunday as long as the weather is decent. i do reccomment clubplug.net good prices basically every plug u could need, iridiums also.
Phax
Car: Control dynamics
Make sure to use a little bit of the gasket goop to get a good seal around the plugs.
Structure240sx
what gasket goop? rtv? i think ill be ok jsut torquing them down to 22lbs
DriFt3r
$5 for iridiums is that right? or is it the copper one?
Structure240sx
as long as u got the right part number its got to be right. the copper ones are about $2 each
