codyace »
https://forums.nicoclub.com/codyace-u28194.html
Tue Dec 22, 2009 6:25 pm
The biggest thing you need to consider when pulling the motor (if trans is attached) ist o get PLENTY of angle (crank pully up, transmission tailshaft down) to pull it out nice and easy. I usually just hook the chain as close as to the front as possible and go from there.
HOWEVER, anymore (if possible) it is 100 percent easier taking these out the bottom.
-Remove exhaust out of way (downpipe too)
-Disconnect radiator hoses
-Remove ECU connector from ecu in footwell, and push harness out into engine bay through the hole...lay harness atop the motor (same as if yo upulled from the top)-Disconnect any wires going to gauges, or wires going to the chassis
-Loosen the 4 front crossmemeber bolts, dont' remove
-Remove driveshaft
-Remove trans mount, and shifter boot/knob from interior (you don't need to remove actual shifter tho)
-Remove wheels
-Put engine hoist and straps around lower rad support, and lower the car onto the ground (like you are actually laying it on the front crossmember gentle). If you have a low dolley (or a old creeper), that works even better as you can now roll push it easier, but it's not needed as you can sort manhandle the motor around
-While car is 'on ground', simple reach in through the wheel wheels, remove the 2 bolts (per side) of the cross member.
Now all you do is use the hoist to lift the car back up, and the motor will be there on the ground. No screwing around being careful not to tear up anyhing, no fighting old mounts to release...just simple as pie.
