I have a 1998 Nissan Altima that the timing chain guides broke and had to be replaced. I ended up having to take the engine cylinder head and intake manifold to check if pistons were damaged. To do so, as you can imagine, I took a lot of parts out around the engine to be able to access everything. I've been doing this on and off in the last 2 years.
so... I can't quite remember where some parts go so maybe you can help. Before embarking in this dismantling adventure all my experience was doing my oil changes and replacing brakes. Surprisingly I have almost everything back together and wanted to finish it all in the next couple of days.
Where does this metal guard go? I suspect somewhere near one of the idle pulleys?
This is a small spring. Does it go somewhere near the throttle?
What goes in these 2 bolts? The 1st image is view from the top, left corner of the engine (when facing the car). 2nd image is a straight down view so you can see the 2 bolt holes.
Lastly, is what bolt goes in this hole right beneath the distributor? My trouble is that once you put the part that sits under the distributor (don't know the name) then it will completely block the bolt hole. That puzzles me what can possible go there then.
