rrack »
https://forums.nicoclub.com/rrack-u1705.html
Wed Jul 18, 2007 3:33 pm
...Just my luck. I double checked the leads to the changer, disconnected, reconnected, turned the key...etc. Still no sound. It appears that there is some sort of signal from the changer. When I crank the volume all the way up I can hear a humming and a slight alternator whine...when I disconnect the changer lead to the head unit (not the power nor remote lead), the sound goes completely silent. I'm thinking that maybe there is a slight possibility that something may have come unplugged inside the unit when I replaced the fuse. I'll pull it back apart as soon as things dry out from week #4 of heavy rains.
I'm just convinced that the changer is working properly now with the replaced fuse...I can fast forward and skip to next songs, just no sound. Unless, something actually fried. I am completely stumped without knowing how the head unit and the modulator works. Is the modulator inside the stereo or somewhere else then leads to the unit? Do I need to or can I set an FM channel on the modulator? Is there some type of reset sequence? Is there a separate fuse for the modulator? Should I post this for the Infiniti Mechanic?
Sorry, Just confused as usual...Robert
