where's the fuel filter....i think i found it, but i'm just makin sure
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
i'm pretty sure this is the fuel filter that i found, cause it looks similar to the 300zx one i am gonna put on. is it in the engine compartment on the passenger side? kinda down to the side of the engine? i'm pretty sure thats where it is.....
Ben '95 SE
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
I'm assuming you have a 95. The fuel filter is a LOT smaller on the 240, so it won't look much like the 300zx filter. It is located on the passanger side, wheel well, about half way down. One gas line on top, and one on bottom. (It isn't attached to the engine like you mentioned) The gas lines will not come off easy! Best bet is to wrap a rag around them and twist them off with a pair of vise grips. Also, before you change it, remove the fuel pump fuse, and turn the engine over a couple of times to help empty out the lines. The 300zx filter doesn't fit into the bracket very well, so fabricate your own, or cut one side off the one that's already there, and secure the filter in there with some large hose clamps.
Spectre
Car: 1995 Nissan 240SX SE
Dude, make sure to have some spare fuel hose with you. Odds are you'll end up tearing a hose if they're really old.
AunVoh
i've used my 240sx bracket for 1 year now, i havent had my 300zx fuel filter come off....
UncleBen
yea i didn't mean attached to the engine, my bad. yea i went back to http://www.240sx.org and got the installation off the FAQ section. do you think the hoses will tear if they are from a '95? i didn't figure they would since they aren't really THAT old. thanks for the replys.
Ben '95 SE
AunVoh
just twist it back and forth when your taking it off, you should be fine.
GoofyATX240
Either that or cut the hoses and just replace them with new hoses.
MaineExport
AunVoh wrote:i've used my 240sx bracket for 1 year now, i havent had my 300zx fuel filter come off....
Cool, didn't you have to cram it in there, becausae the size difference is significant!
Daunttless
You have to cram, but it fits. : )
UncleBen
kool
Ben '95 SE
Spectre
hey man, fuel hose isn't expensive at all. It's just handy to have around incase you cut a hose. Keep some with you just incase.
s14=pimpin'
Car: 1995 Nissan 240SX SE S14
mine fit into the bracket as well, and seems to be snug. Your hoses should be fine Ben, jsut be gentle with them and take your time.
Paul
UncleBen
i'll try not to get in a hurry, and it sounds like i should be fine. thanks for the help. i was gonna put it on tonight but i went swimmin w/ some chiks instead:D tomorrow i guess i'll do it.
Daunttless
At least you have a good reason. We can accept that so long as they are adequately attractive. : )
UncleBen
HA HA, "ADEQUATE" doesn't come close. i tell you what, if they looked any better, well, i don't know. for real, they were most definately "adequately" attractive. plus we were swimmin, so they were in bikini's:naughty
Daunttless
then you better have done more than gone swimming. : )
UncleBen
don't worry about it, just use your imagination. anyway, i got that fuel filter on. it was easy, and it fits in the holder very snug. i'm happy with it.
MaineExport
Now you just need to get the 300zx fuel pump and JWT rails to make it worth while!!!! Not sure if it actually does any good, but why the hell not!
UncleBen
maineimport wrote:Now you just need to get the 300zx fuel pump and JWT rails to make it worth while!!!! Not sure if it actually does any good, but why the hell not!
what are "rails"
AunVoh
the injector rails
UncleBen
ahhhh got ya:cool:
GodDrivesA240sx
well you already got it on, but for the other people that search and find this topic maybe this will help :)
I got bored and decided to see how well this pos camera takes pictures in daylight, after a little editing it looked the best the camera was capable of.
oh yeah. the yellow arrow shows where the top of the filter is
GodDrivesA240sx
GodDrivesA240sx wrote:well you already got it on, but for the other people that search and find this topic maybe this will help :)
++++++PREVENTION++++++
ANY NEWB THAT IS LOOKING FOR THE FUEL FILTER THERE IT IS!!!!
