cucarachafea wrote:So..... how did you get it out???
Since I didn't know what I had to do to remove the blank, I removed the entire switch panel. First, I rmoved the fuse access door below and the access panel on the left. A thin blade was used to wedge out the left access panel. The switch panel has three small screws holding it in front the back side (top, left and right. A stubby phillips head works best.
The blank is held in place with two notched tabs, one on the top and one on the bottom of the back side. If you can get a thin blade between the knotched tab of the panel and the top or bottom of the blank, the blank will pop out toward the back.
The following picture is of different notched tab item under the dash, but it will give you the idea:
Modified by c5neb at 5:57 PM 5/22/2007
