M374llic4 »
https://forums.nicoclub.com/m374llic4-u35918.html
Mon Mar 29, 2010 8:28 am
Strangely the plug under the column that has the blue, white with a stripe, black/yellow, black/green and black/white plug, the side of the plug that is on the column, the wire colors do not match up with the side thats connected to the harness.
These wires were obviously cut and twisted back together on the side that is attached to the column.
When I wire the plug on the column to match the wires off the ignition the car turns over when the key is in the normal ON position, but the ECU gets power at the same time. If I wire it so that the wires match the plug on the harness, the car turns over at the start position as it should, but does not get power to the ECU when in the ON position.
