elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Aug 18, 2003 11:26 am
Check all drain plugs...... There are 4 or 5 on the drivers side door (bottom)...... On the left side (facing the door from the inside of the car) there is a square one, and a round one...... Then there should be a round one (maybe square, I cant remember off hand) and then a round and a square on the right side.... If they are plugged, get some compressed air and start blowing!
Check them by opening the door, and get a glass of water and pour it on the window, so it seeps down.... Water should come out the holes.... If not, then theres your problem.....
Check your sunroof drains by opening the sunroof.... From there, you should see 2 holes on either corner..... Get some water, and pour it down there..... You should see water dripping from the botton of the car (rocker panel)......
I checked the service manual, and Im not sure where the drain hoses end at for the sunroof, but Ill check....... In the mean time (if they dont wont work), blow them out with air......
