http://www.ttzd.com/tech/autocctech.html
ok so i went through the test and here are the results.
Monitor Diagnosis Mode:
Def icon only Ambient temperature ºC(ºF)
87
Upper vent icon only Upper cabin temperature ºC(ºF)
00
Lower vent icon only Lower cabin temperature ºC(ºF)
99
0 Fan & Def icon DEFROST outlet air temperature ºC(ºF)
04
0 Fan & Upper vent icon VENT outlet air temperature ºC(ºF)
04
0 Fan & Lower vent icon FOOT outlet air temperature ºC(ºF)
00
1/4 Fan & Def icon Sunload *1
06
1/4 Fan & Upper vent icon water temperature *3 ºC(ºF)
68
1/4 Fan & Lower vent icon Mode door voltage *4 *2
02
1/2 Fan & Def icon N/A
00
1/2 Fan & Upper vent icon N/A
53
1/2 Fan & Lower vent icon N/A
53
3/4 Fan & Def icon N/A
30
3/4 Fan & Upper vent icon N/A
42
3/4 Fan & Lower vent icon N/A
68
Full fan & Upper vent icon Difference in upper & lower temperatures ºC(ºF)
00
Full fan & Lower vent icon N/A
05
Actuator Test Mode:
Defrost icon - Mode door - DEF, DEF/Lower, B/L, VENT -
48
Defrost and lower vent icon - Intake door - FRE, FRE, 50% FRE, REC -
31
Upper and lower vent icon - Air mix door - Full hot,Full hot, 30ºC(86ºF), Full cold -
13
Upper vent icon - Compressor - OFF, OFF, ON, ON -
1
Upper and Lower Temperature Difference Mode:
ºF spec. Data -36 to -2 0 2 to 36
ºF spec. Difference between upper and lower target temperatures -3.6ºF to -0.2ºF 0 0.2ºF to 3.6ºF
-35,-34,-33,-30,-29,-27,-25,-24,-21,-20,-18,-16,-15,-12,-11,-9,-7,-6,-3,-2,00,02,03,06,07,09,11,12,15,16,18,20,21,24,25,27,29,30,33,34,36
Trouble Codes:
No codes were given
