where is the surge tank/ manifold pressure regulator
Danogtr
Car: 1989 240sx with sr20det swap red top
hi, im trying to install an Apexi boost controller. avcr.. i dont know where the surgetank pressure regulator is and where to install the pressure sensor. anybody know? and.. where is the best mounting location for the actuator valve? thanks
The Mic
Car: 3Z Wmb
Do you have the instruction manual? If not, here it is: http://www.apexi-usa.com/pdf/t...0.pdf
