Where is the OBD2 Connector
searogue
Car: 2008 Nissan Rogue SL AWD
Looking for it - I know it should be here somewhere....
philipa_240sx
It's on the bottom edge of the kick panel just below and slighty to the left of the steering wheel. You may have to look up from the floor to see it. It's a 16 pin connector BTW.
searogue
Found it! Thanks!
sckeith
Car: 2017 Versa Note SL, Red
I was under the impression that the Rogue was not OBD2 but another standard. I believe it was something I read here that makes me think that. I'll do a search later to see if I can find what I read
philipa_240sx
Did a quick bit of research:
You might be referring to the ISO 15765 standard... basically the CAN bus system. It's part of the same diagnostic (OBDII) connector above. It appears this new 'standard' is required on all 2008 and newer cars in the US. I imagine some older OBDII scan tools may not be able to work with the newer CAN bus system.
From a quick glance at the wiring diagrams, the Rogue 'may' support conventional OBDII diagnostics for the engine, transmission, air bag and ABS ECU's. Everything else is done via CAN bus: BCM (Body control module), AWD control module, and intelligent key control.
Return to “Rogue Forum”
