where is the neutral safety switch?
nka24racr
Car: 91 acura integra, but missing my chuki......
my car wont crank, battery is fine and so are grounds, its either my solenoid switch or neutral safety switch, i tried to bypass my solenoid, and it spun the starter but wouldnt crank, and i need help to locate the neutral switch, wat do i look for! need help asap..........
nka24racr
i need some help here.........
Scuffed_ChukiCoupe
Car: Ka-t coupe
Your car is automatic? I belive it is in the transmission area.
psilocyben
Car: 1992 240sx
If you have a 5 speed I think what you are looking for is behind the clutch pedal. But if you spun the starter I dont think the neutral safty switch is your problem, because the neutral safty safty switch must be closed for the starter to get power to its coil. I am not totaly sure because Im not there. Have you taken your battery to a auto shop and have them put a load on it?
TheOne
Car: 93 240sx FB
if you did an auto to manual swap, the neutral safety switch wires is the top connector next to the fuse box in the engine bay(by the battery)
pr240sx
It the engine cranks, forget about the neutral switch.
Check for spark and fuel.
