onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Wed Jun 15, 2005 8:10 am
swivel sockets are your friend. Took me a whole day just to change my starter.
I have an 89 sohc, it would have been a lot easier if I removed my heater hose (didn't - that's why it took a whole day). So if worse comes to worse, remove the lines that are in the way of the starter.
If I remember it correctly (and if dohc is same as sohc), that last bolt is really close to the firewall toward the back... where you have about 3-4 fingers of clearance - I swear, sometimes I looks like Nissan put the starter in first, then built the car around it, ahhaha.
Get someone w/ small hands if possible.
Like the other guys said, you probably will barely be able to see the bolt, you just have to "feel it up".
Good luck!
