Where is the IPDM Located? Help!!
redline240sx
Car: 1991 240sx
If anyone know where the IPDM is located in a 2004 Nissan Pathfinder please post up and pics or links that cant help me out.....Thanks
Pwnin O'Brien
What is the IPDM? The fusebox?
redline240sx
Car: 1991 240sx
"Intelligent Power Distribution Module"
Its a unit that has fuses and relays..
I am looking for a ECM relay and found out that it is located in the IPDM unit..
Pwnin O'Brien
Sorry, Nissan doesn't use the term IPDM for the R50, they just call it Relay box-2. You can find the ECM relay in the black relay box positioned next to the passenger side strut tower (towards front-of-vehicle). The ECM relay is the relay closest to the passenger fender.
redline240sx
Car: 1991 240sx
Can you by any chance send me a link to how it looks exactly, because i tried looking for it but really cuddnt tell which was which since i lost my fuse box cover..
My pathfinder has trouble starting up, doesnt turnover. I was told that the IPDM goes bad for pathfinder (the ecm relay) and to switch it with the fog relay because they are the same relay, so im in the process of doing that once i figure where i can find both relays........Any help will be appreciated, Thanks.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
http://www.nicoclub.com/FSMCheck that out... Should help you get started
Edit.. Thanks, kyooX4... Fixed the link.
KyooX4
Car: 2001 Infiniti QX4 4wd
Make sure you take the extra C out of that address.
elwesso
2007 BMW M Coupe
thanks for pointing that out..
