Where is the iacv at?
mss5413
Car: Nissan 240sx
Can anybody tell me where the idle air control valve is at? I have had posts that this could be my problem. Either I need to clean it out with carburetor cleaner or clean the connection. Which one should I do or both and how is it supposed to be cleaned? Is is near the transmission on the bottom portion of the intake manifold?
MaxType 240
Car: 1995 S14
Here's a write-up of my experience w/ pics:
http://www.tamparacing.com/for...Clean
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
It is attached to the rear of the intake manifold collector. It has a screw you should be able to adjust the idle with. As far as taking it out to clean it, PITA.
clearview
its a pain in the *** to get off the car. order a new gasket before you take it off . i cleaned mine with some goof off. it had tar like crap restricting the parts from moving freely.
mss5413
Car: Nissan 240sx
Since my car has about 120K miles on it and I have not touched or cleaned the iacv yet, are you saying that it will definitely have build up that is causing my intermittent rough idle?
MaxType 240
Car: 1995 S14
Yes, clean it. It will feel like a new car, purr
