Where is the Fog Light fuse?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
dx3
Car: 2006 Infiniti QX56
I recently installed some H3 HID's for my fogs. They worked for a couple of days and then nothing. I haven't pulled them apart yet to test for power, as I would like to check the fuse first. The owners manual completely sucks as far as fuse locations, so I was wondering if anyone had a copy of the fuse locations or knows where the fog lights fuse is on an 06 QX?
Thanks,Jonny
iNfinitiNBeYond
Car: 06 Infiniti QX56
Yo frend.. I think you did blew a fuse... The fog lights are not HID. Yes H3 but I think you have to buy an HID Kit. The fuse box are usually located in the engine area... I not really sure... but most jap cars are located under the hood.. so check there, but look into your lights first before you buy more spendy lights... I haven't upgrade mine yet either. I wanted to change all my lights to the same color maybe..... But also wanted more high intense lights as my regular headlights which I believe is HID....and the highbeams.... I believe you can just upgrade it to H3 LEDs which is a little brighter and actually uses less voltage...So.. Yeah...But the HID headlamp bulbs do not run on low-voltage DC current, so they require a ballast with either an internal or external ignitor.
Automotive HID lamps are commonly called 'xenon headlamps', though they are actually metal halide lamps that contain xenon gas.
Modified by iNfinitiNBeYond at 9:08 PM 6/2/2009
dx3
Hey man,
Sorry - I should have given you a little more information. I actually have already installed my H3 HID's in the car. I had them left over from another project so I figured I would throw them in the QX. They worked for a couple of days but then quit. I finally found the location of the fuse I was looking for last night after some kind assistance from another forum member. Turns out it was blown. I will put another fuse in an see if it blows again. As luck would have it, I have a box of every fuse at home, aside from the 20a that I needed
Actually - if you are planning on it. The H3 HID install is very simple and there is a perfect location to mount your ballast. It looks really cool. Unfortunately my H3's are 6000k and I believe the HID headlights we have are 4300k so the color is a little off. I replaced the rest of the front lights with "cool white" LED's but they don't match like I had hoped. I will try and get some pictures of it tonight if I can.
Thanks for your help man,Jonny
Return to “Armada Forum / QX56 Forum / QX80 Forum”
