where is the fill plug?
racin-type
Car: cars
For the transmission? i kno where the drain plug is but wheres the fill plug? and is it true that you can fill it through the shifter hole inside car, if you fill it that way how do you know when to stop??
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
Thats how you fill it, through the shifter hole. I'm not positive one how you tell when it's full.
rousie13
When I replaced my clutch, I just looked up how much it held and put that much in. Then just made sure it looked correct and shifted fine.
SET240SX
Car: fast rides
The fill plug is on the drivers side about mid transmision. To fill from underneath car you need to attach a hose to the bottle of oil and squeeze it in. Or pull the plug and fill through the shifter until it starts coming out the fill plug.
ride4lame
follow set 240's instructions. There is a device my dad had that i uaed that is like a thing for icing a cake. It sucks the fluid and pushes it out. Be warned though, gear oil smells bad as hell.
racin-type
Car: cars
Thank you very much Set240sx
i have the FSM but it didn't show the fill plug but did the drain plug someone needs to get slapped over there but its not a major thing just didn't wanna waist time jacking and looking for it. 5 1/8 pints right? oh and is 75W85 ok? FSM said 75W90. thanks again
Touchdown038
Car: Computers, cars, sports
Either one will work, but heavier-weight oils are better if you have an older transmission / worn syncros.
Hope you have air tools to take that fill plug out with, or a way to get the car up high enough so you can fit a breaker bar on the plug. Mine was rusted in there very badly, and only a shop's impact could take it out.
drifter sx
Car: the usual
use the shifter hole. you'll need snap ring pliers to get the sfiter outta there. i used 4 qts of gear oil and that did it just fine. good luck
Zero-s13
Car: driving canyons, playing video games and taking care of my reptiles
I just went through this ordeal yesterday. I saw that my fill plug was stripped to $hit so my friend had the idea to release the drain plug to kill some of the pressure to make it easier to get the fill plug out. Basically what happened was the fill plug was not coming off ( too stripped) so i had to take out the shifter and pour it in through there. But you dont need to use the needle nose to get it out. At least I didn't. what I did was take all the shifter boots off and the there will be a plate w/ a ball joint in it. Take that plate off it has 6 bolts on it, 4 you can get from inside the car and 2 more right in front of the other for that you have to get by hugging the transmission from underneath. Sorry if it post was too long. Hope this helps a little. -Jeromy
Touchdown038
drifter sx wrote:use the shifter hole. you'll need snap ring pliers to get the sfiter outta there. i used 4 qts of gear oil and that did it just fine. good luck
Nope... he was right when he said 5 1/8 pts. The whole crankcase doesn't even hold 4 quarts.
racin-type
Car: cars
hmmm rusted bolts or stripped huh? hope mines is in better condition. if not i'll just pour thru the shifter hole. What are snap ring pliers? it rings a bell but doesn't come to mind would regular needle nose pliers work? can you use that same snap ring again? will be doin in a few hours wish me luck.
everything seems to be harder on our cars damn rust.....
lbrowne
I was going to do this myself as well until i got the center console out and looked at the shifter setup, I couldn't figure out what it was I had to do to get the shifter out so I left it.
I too, was told 4 qts on this forum, and was indicated by NAPA that that is what the transmission should hold. (actually its a hair less than 4 qts)
EDIT: on the bottles of gear oil I have, they have a pointy tip of a spout. when I had the console out I noticed that there were a couple of small holes that appeared to go right into the transmission without removing the shifter......but I never tried it. But I figured the lil pointy spout would fit right in there....
Blackstar
Car: 1995 240sx
yea, you can fill it through those tiny holes without actually taking the shifter out, but it takes a long time and I wouldn't risk spilling gear oil in my interior cuz the smell will never go away. I filled mine through the fill plug using a hose, ( I personally don't like the fill through the shifter thing, cuz I figure if you gotta jack up the car to drain it, why not just fill it there too?) then you can just stick your finger in the hole to see if its full. I think it takes just under 3 qts if I remember right
racin-type
Car: cars
WTF!!! this is messed up looked at it today and guess what? couldn't even get the damn drain plug off aaaaaaahhhhh 1)THAT plug is messed up a lil, so when i put in the 1/2 ratchet in its real loose and 2)its tight as hell.
but even before i tried to drain it look into that shifter thingy. took off the bracket then the rubber boot and then tried to get that snap ring off no luck. so i tried "Zero-S13"'s way but them two nuts that u gotta hug the transmission to do, was not gonna work for me. then went to buy a vacuum pump to pump the oil in and found out i couldn't get the plug out.
anyway i'm goin to the nissan dealer when i have time to get a new drain plug, return the vacuum pump and get a shop to air gun that ****** out. damn all this just to change the damn transmission oil. i didn't even have to get under the car on my honda.
oh and to clear up that 4qts/3qts bs ... ITS 5 and 1/8 PINTS !!!2pints a quart so 4qts = 8pints thats way too much and 3=6pints. its in the FSM thanks for all the help anyway.
Touchdown038
5 1/8 pts. is right. Straight out of Chilton's.
Whoever told that one guy that 4 qts. is the right about was way wrong. The damn crankcase doesn't even hold that much!
SET240SX
Car: fast rides
Sorry to hear the trouble about getting the plugs out.
You can probably go to a local lube shop and have them pull the plugs and fill the transmission with your oil really cheap.
They know how to get them out they do it all the time. Just wouldn't trust the oil they use.
Philip
Gonad
On an M/T, you fill through the shifter. Take the shifter out andfill.
For the differential, there are two holes; a drain hole at thebottom and a fill hole on the side (driver side). You'll need a tube/hose to pump the fluid in.
racin-type
Car: cars
yo i'm real tired of people spreading info that is incorrect or not wholey tru. on a M/T there IS a FILL PLUG. HOWEVER you can ALSO fill thru the shifter.
Gonad
The shifter is prollly most convinient and easier. :)
lbrowne
Can someone in very simple terms/steps indicate how to remove the shifter with just the needle nose pliers?
I would really like to do this on my 240 this weekend. I can get the console out in seconds, I'm confused where to go with this snap ring business, where do I start....where do I look?
thnx,
lbrowne
Touchdown038
Removing the shifter is a piece of cake with the right tools. First, twist off the shift knob. Then pull up the black trim going around the shifter all the way up to the vents, and the leather boot should come with it. Removing the two dust boots below that, there should be 4 12mm (IIRC) screws. After that, pull the black rubber thing up just enough to see beneath it. Then you come to the C ring - a good pair of C-ring pliers should remove it. You might have luck with a good pair of needle-nose, but it's a LOT harder. Best to go buy the pliers, they're like 5 bucks at any car parts place. After you pull that ring, the shifter should pull straight out.
lbrowne
Does it matter what size c-ring pliers I get....do they vary?
LIke I said I can get right down to the nitty gritty, its that c ring clamp thats stoppin me.
Touchdown038
I don't think it matters what size... some of the ends on them are too big to fit into the two holes, but most of them come with different end pieces and most of them will fit.
racin-type
Car: cars
yea that c ring thingy messed me up other then that was easy gettin to that point
lbrowne
Gah, I went and picked up the transmission fluid from my gf's garage that I had bought after researching here how much I needed at the beginning of this year. I have 3 one liter bottles and theres about 2 pints in a liter.
Which means I bought those because I needed 5 and a bit.
Sorry for adding any confusion. :)
