where is the difference between cam sprocket and cam pulley?
Fenvy
Car: 2005 350Z Base 6MT
can't find more info on that
also, hks's cam sprocket comes with CAS gear for the exhaust cam... how come toda, tomei, greddy don't have that?
sr20detmaybe
Car: 95 240sx
sprocket is for a timing chain(what SRs have) and cam pulley is for a timing belt (Hondas, DSMs, etc....), correct me if im wrong, im not sure about ur second question.
Fenvy
check these out...
hks cam pulley for sr20det
greddy cam sprocket for sr20det
I am confused..?
VitaminT
Car: 93 240sx SE
The picture of the HKS pulley is for a RB or CA (probably RB since it is marked that on the pulley). Both of those motors run timing BELTS.
Anytime the pulley/sprocket is thick like that it will be for a belt.
On the other question as to why HKS SR sprocket has the CAS worm gear and the other brands do no I am not sure. I am betting the others just expect you to use your existing stock worm gear, helps lower cost too probably.
180fan
Car: 89 fastback
Yes you pound out the gear on your old sprockets and hammer them into the new cam sprocket.
Fenvy
would you say hks unit is better because it has the new one or others such as greddy is just as good?
UK-SRi
Car: Nissan Cima 2007/2008
If you are after a cam sprocket for an SR20, go to G20.net or sr20forum.com and look for "P@" and Yahnozha, he does a +-4 or +8 or -8 1 degree locking set that is good quality and wont slip like the infinitely adjustable ones may do. made by his company "Custom Steel".
Mike
Dori Dori
Car: Cars of course
JWT has non slip sprockets too...and they're cheap!
UK-SRi
JWT sprockets are only adjustable in 2.5 degree increments, which is often too coarse, esp for a turbo where you have to finely control the overlap. I think if you look you will agree the price and quality are both good for the custom steel sprockets.
Mike
Dori Dori
Car: Cars of course
I'll check it out...link to an actual store web store?
UK-SRi
tonis56
Car: 04 Titan Crewcab
UK-SRi wrote:JWT sprockets are only adjustable in 2.5 degree increments, which is often too coarse, esp for a turbo where you have to finely control the overlap. I think if you look you will agree the price and quality are both good for the custom steel sprockets.
Mike
Arent they one time adjustable, I may be wrong. This is just what i remember.
UK-SRi
Nope, but you do need to separate the cam and gear each time you want to adjust.
Mike
tonis56
UK-SRi wrote:Nope, but you do need to separate the cam and gear each time you want to adjust.
Mike
ahh i see.
UK-SRi
The solidity of having to do that is why they cannot slip, slipping has destroyed many motors like the SR20 with interference heads.
Mike
