OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Fri Oct 02, 2009 9:26 am
Air fuel and spark.... Make sure the engine is metering the right air.... (check the maf, make sure the timing and plugs/ignition are good, check the fuel pressure and fuel rail/injectors for leaks.
Check and clean the throttle plate and AIC. Check the CTS, make sure its not reading "warm"
If you don't know what some of this stuff is, then I can see how the FSM is not helping.
