Where is the carburetor located in 97 maxima?
signals
I looked up in the index of service manual. I don't see the term carburetor listed. How do i identify the part and how do I clean it? Thanks for your help.
Darktide
for the simple reason that our cars do not have carberators. We have throttle bodies. Carbs were taken off cars for good back in 1987. Why do you think it needs to be cleaned.
signals
I was looking for reasons for poor acceleration! The car has 120K miles. I wish to know what I should look for and replace/repair. Thank you for bringing me several decades ahead
Darktide
I saw your other post afterwards. What year/model car do you have. First things first.1) Fuel Filter2) Air Filter3) Run some fuel system cleaner through4) You've done the spark plugs5) double check your tire pressure6) Check your transmission fluid.7) Get the car checked for codes
If it's a 3.0L Max then you should have a pretty powerful car on your hands. Those are the first steps towards getting more power. You could be looking at your O2 sensors slowing down and giving bad readings. But you should always start with a good tune-up. You don't have any plugs/wires/ignition coils on these cars either. If you're still in the days of carburetors then you won't be happy with the fact that this type of problem is not as easy of a fix as it used to be.
Keep us posted and I'm sure more people will chime in with info
Joe
hate to break it to you darktide, but it has spark plugs.
MaximA32
Darktide wrote:You don't have any plugs/wires/ignition coils on these cars either.
Kamin wrote:hate to break it to you darktide, but it has spark plugs.
I also hate to be the bearer of bad news as well but, he has coils too.
Joe
good catch. i was more focused on the fact he doesnt think they have spark plugs.
Darktide
it was a typo. I meant plug wires/coil. I got carried away with the '/'s . As for ignition coils. Since the OP thought that the car had a carburetor then I'm hazarding a guess that he wouldn't think of coils in the same context as you two would. I should have explained that the motor uses a coil-on-plug system and not the single ignition coil/cap/rotor/wires that the older cars used.
Darktide
Kamin wrote:good catch. i was more focused on the fact he doesnt think they have spark plugs.
if you had read my entire post you would've realized that it was a typo since I listed the fact that he had already changed the plugs in #4 on my list. Seriously.
WDRacing
I suggest building a turbo kit...
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
WDRacing wrote:I suggest building a turbo kit...
Why would you even suggest that on a carburetor application??? J/K!
<<< signals >>>
darktide did lay some good thoughts for you in that post. Look into doing what he has listed and see f that fixes your issue.
lightsout
Car: 00 Nismo Maxima SE
i'm with Darktide!! clean clean clean your filters, fluids, and combustion chambers...that should help lots. Get the car scanned and keep coming with questions!!
Gman8990
Car: Pearl 1999 Nissan Maxima GXE
If you really want more acceleration AFTER all that stuff a Y-pipe or exhaust is the way to go
turbospotter
that kills acceleration. You need backpressure for that!
