mss5413 »
https://forums.nicoclub.com/mss5413-u20429.html
Sun Oct 31, 2004 1:26 pm
The hose is beneath the intake manifold. It connects to your pcv valve which is a threaded component. If you are going to take the trouble to get to your blow by hose you might as well buy a new pcv valve just incase yours it stuck and does not rattle when shake it by hand. Anyway, the easiest way to get to it is to remove the oil filter and the intake manifold bracket. The bracket has two bolts on top and one on bottom. Then that should give you enough clearance to get in there with needle nose pliers for the clamps and a socket with and extension for the valve. You can check your hose for cracks or whatever at this time. The hose costs about $22 from the dealership and is curved from the factory. Good Luck!
