niznos »
https://forums.nicoclub.com/niznos-u14767.html
Sat May 15, 2004 7:10 am
Generally speaking, if they don't work, they are stuck closed. The fuel injector is a little electronic valve to put it in simple terms. Normally, the injector is closed, when a electrical charge is sent to the injector, it makes a tick as it opens and closes in a split second. I suppose anything is possible, but it being stuck open is rare.
To be sure, you can inspect your sparkplugs after a while of driving. A normal plug should have a light tan or gray color; but if a certain cylinder is running rich as in injector stuck open, it will have black soot on it. Either way, if it's not working, open or closed, you need to replace it. Again, I would say just do them all to make sure all 4 are working in the same condition.
