Where is the ABS module?
Andrews Chalmers
Car: Versa '07 SL CVT
A fellow Versa owner from another country asked me whether she had ABS on her vehicle or not - ABS aren't standard for the Versa/Tiida models - how can I advise whether she has ABS or not?
Anyone know where the module is located? Diagnostic tests? From what I understand - the ABS red light only comes on if there is failure/error?
thanks in advance!
Andrews Chalmers
shameless bump
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
Here are the diagrams from the Service Manual. It also contains diagnostic tests, although some require Nissan test equipment and software.
Andrews Chalmers
so to the rear/left of the engine by the strut tower?
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
Facing the engine from the front, it's behind the metal heat shield mounted on the firewall by the passenger's side. If the car is equipped, the ABS light will come on when the key is switched on, just like all the other warning lights.
Andrews Chalmers
Dammit - she got conned by the dealer.
