My A/C quit coming on suddenly. The clutch is not engaging.. There is plenty of pressure in the system (60 - 80 lbs with the compressor disengaged.) All fuses are good.
I wanted to try jumpering around the compressor relay to see if the clutch engages, but I cannot find it. The manual makes it seem like it should be in the IPDM fusebox (the one on the firewall next to & below the battery), but the diagram of that box that they show has all the relays labelled, and none are the A/C clutch relay. Same for the other 2 relay boxes under the hood.
Where the heck is it?
